seasonal adjustment
efes
seasonal adjustment
Postby efes » Fri Dec 26, 2008 9:43 am
hi,
i ve just joined this forum and i am a newly user of eviews . What i want to ask is that:
i want to make seasonal adjustments with eviews. I have copied the serie to eviews but when i clik to proc button it says resample... and no menu appears about seasonal adjustment. Anyone can tell me what do i wrong ?
Re: seasonal adjustment
Postby EViews Gareth » Fri Dec 26, 2008 10:48 am
Can you tell us exactly what it says under the Proc menu. What other items are there other than Resample?
efes
Postby efes » Fri Dec 26, 2008 11:13 am
only "RESAMPLE..." appears. Nothing else appears. When i click resample, a menu is shown and it includes opsions like "sample to draw" , "sample to fill" and "NA handling" . I also dont know what those means...
Postby EViews Gareth » Fri Dec 26, 2008 1:22 pm
I can't think of anything you could have done, off the top of my head, that could cause that. Could you post your workfile?
efes
Postby efes » Fri Dec 26, 2008 1:37 pm
here is the file... when u open "oil price" series , in the proc menu nothing appears except for "resample..." . may be i am making a common mistake . as i said i am a newly user. thanks...
deneme.wf1
(9.85 KiB) Downloaded 890 times
Postby EViews Gareth » Fri Dec 26, 2008 1:40 pm
oil_prices isn't a series its a group (hence the little G symbol). If you open up the series called SER01 (which contains the same data), you'll be able to do the seasonal adjustment.
efes
Postby efes » Fri Dec 26, 2008 1:51 pm
as i guess it was something simple but i dont know ... thanks a lot
jayk
Postby jayk » Wed May 05, 2010 10:09 am
I have a follow-up question on the seasonal adjustment question. How can i seasonal adjust a group of series (more than 10) without doing it for each individual series? When I group evrything together, the seasonal adjustment option is not available....please help...
Postby EViews Gareth » Wed May 05, 2010 10:42 am
Other than writing a program to do it for you, the only option is to manually do each of the ten.
