better fitted values
Postby startz » Tue May 04, 2010 10:01 am
Consider the regression
ls e^2 c x
If you ask for the fitted values of e^2, you may get the message can't raise negative number to a non-negative power. Now it's true that if you try to forecast e you may run into difficulty, but e^2 is always straightforward. It would be nice if the forecast of the actual LHS variable could be special cased so that it always works.
Re: better fitted values
Postby startz » Wed Apr 27, 2011 4:54 pm
ls e^2 c x
(1) bump
(2) The forecast dialog even offers to forecast the actual LHS variable, and then fails.
Postby EViews Glenn » Thu Apr 28, 2011 9:41 am
I've seen this one before and am sympathetic, but to do the special casing you're asking for we'd have to write a separate forecast engine for just this case (static, dependent variable fit--note that you can't do it in any dynamic settings). This one is on our list, but there's a fair amount of complexity in there and since the user can do this by re-estimating after generating the dependent variable, this hasn't worked its way to the top of the list.
But I am sympathetic, really...
