Impulse response functions
samus_soul
Postby samus_soul » Wed Apr 28, 2010 12:09 am
Hi. I having a problem interpreting/understanding the basic impulse response graphs.
I have two I(1) variables in a reduced form VAR model using a 1 s.d shock on their residuals.
When var1 is shocked, the response from var2 graph is it increases by 0.2 s.ds while a shock in var1 on itself causes a response of it to fall by 0.2 s.ds. Does this mean that var1 and var2 have an inverse relationship? I.E the shock/innocation on var1 negatively effects var1 but posititvely effects var2?
Many thanks with any help you can give.
nadja123
Re: Impulse response functions
Postby nadja123 » Wed Apr 28, 2010 3:17 pm
Hi, why don't you try to add concrete pictures and tell what your variables are? These should have some economic meaning. Plus try to tell whether you use annual, quarterly or other data, how many lags you included and what factorization you used.
samus_soul
Postby samus_soul » Wed Apr 28, 2010 4:31 pm
Hi. The variables are logs of fuel exports and manufacturing exports.The data is annual. There is 2 lags to the reduced form VAR (as suggested by AIC criteria).
I have attached the generated responses to this post.
Thanks for any help. :)
raw impulse response .png (18.92 KiB) Viewed 18345 times
nadja123
Postby nadja123 » Thu Apr 29, 2010 2:03 am
1st of all, your impulse responses appear quite unstable. Have you checked out VAR / View / Lag Structure / Lag exclusion test and Lag length criteria? Have you verified the stability of the model under VAR / View / Lag Structure / AR Roots Table?
Interpretation of IRFs: I think they are not correctly estimated, but let me suppose they are correct as they are (I mean sign and evolution...) Then, both your variables yield a positive response (increase) to own positive shock (unexpected increase). The same appears in the case of mutual shocks.
(I do not quite understand why it is interesting to analyze fuel and manufacturing exports in a bivariate VAR.)
Good luck with your work!
