Hi there,
I've started using the debug function which I find very useful for finding out the values of programming and replacement variables at a certain state of the program. However, I'm using quite a lot of these variables so not all of the variables are shown in the Watch window. It seems to be a cut off at 99 rows (100 if you count an empty row at the end). Is there a way to increase the number of rows covered by the Watch window?
Kind Regards
Tomas
Debugging - number of rows in the Watch window
TomasThoren
Re: Debugging - number of rows in the Watch window
It's probably a hard upper limit. I'll look into it.
By the way, which version of EViews are you using?
TomasThoren
Hi Steve,
Thank you. I'm using Eviews14 Enterprise Edition - Oct 22 2024 build.
Kind regards
Tomas
Kind regards
Tomas
Found it. Will be fixed in the next patch.
TomasThoren
Great! Thanks!
/Tomas
/Tomas
Patch is out.
