Hello
I am filling a matrix with column vectors using colplace, is there a way to limit the number of decimals in a given column? Setcell allows this by specifying the fixed decimal as the last argument, but this does not work with colplace.
Thank you
fixed decimals in matrix
Re: fixed decimals in matrix
Display or actual?
Do you mean by "actual" the values of the initial vector (possibly subject to further calculations) and by "display" the values displayed as results? If so, displayed. What I want is to display the values of the column vector in a matrix with fixed decimals.
Once you have the matrix filled, use setformat:
https://eviews.com/help/helpintro.html# ... 23ww175785
