I want to calculate the p-value for a non-linear combination of coefficients estimated in an ARCH/GARCH model in EViews. Is there a way integrated into EViews to calculate the variance and p-value of a nonlinear combination of coefficients (as with the nlcom command in stata)? Or do you have to extract the variance-covariance matrix, calculate the partial derivatives and program the Delta method “by hand”?
thanks for any help
Bob
Is there an equivalent to the nlcom command (Stata) or the Delta method integrated into EViews?
Re: Is there an equivalent to the nlcom command (Stata) or the Delta method integrated into EViews?
There is sort of a kludge to do this. After estimating an equation do View/Coefficient diagnostics/Wald test.
Then enter the nonlinear formula you're interested in, like c(1)/c(2) = 0. You get the value of the formula, the standard error, and the t-statistic.
