estimating the the BTVC-VAR model.
ndzama
Re: estimating the the BTVC-VAR model.
Postby ndzama » Fri Sep 13, 2024 5:58 am
Hi Gareth,
I would like to inquire if there is an add-in or command available for conducting forecasts using estimates from a Switching VAR model (MSVAR). Your guidance on this matter would be greatly appreciated.
Kind regards,
Nwabisa Ndzama
ndzama
Postby ndzama » Fri Sep 13, 2024 6:07 am
Hi Gareth,
This syntax didn't work:
ca_{%c}_var06.forecast(f=na) NNS
'Error message: Forecasting is not available for this VAR estimation method in "CA_{%C}_VAR06.FORECAST(F=NA) NNS" on line 1913.
Kind regards,
Nwabisa Ndzama
Postby EViews Gareth » Fri Sep 13, 2024 8:20 am
No.
ndzama
Postby ndzama » Thu Oct 10, 2024 5:56 am
Hi Gareth,
With Eviews 14 I was able to successfully estimate the BTVC-VAR model.
Thanks,
Nwabisa Ndzama
ndzama
Postby ndzama » Thu Oct 10, 2024 6:01 am
Hi Gareth,
Thanks,
Nwabisa Ndzama
ndzama
Hi Gareth,
Thanks,
Nwabisa Ndzama
ndzama
Postby ndzama » Sun Oct 13, 2024 6:21 am
Hi Gareth,
I trust you are well.
I have tried to estimate the STVAR, using both the Maximum Likelihood Estimation and the NonLinear Least Squares (nls). I get an error message. Please see attached files.
Kindly assist,
Nwabisa Ndzama
Screenshot 2024-10-13 150707.png (254.76 KiB) Viewed 33196 times
stvar_model_nwabisa_ndzama.prg
(10.06 KiB) Downloaded 24092 times
