I am currently working on a panel data set with N = 45 and T = 27 and estimating a Pooled Mean Group (PMG) model in EViews 14. The model consists of one dependent and one independent variable. I have selected the optimal lags using the Akaike Information Criterion (AIC), with a maximum lag length set to 4. The model estimation proceeds without any issues.
However, when I attempt to run the ARDL diagnostic tests, specifically the Bounds Test, EViews 14 either becomes unresponsive or unexpectedly shuts down. I have tried different configurations, but the problem persists.
Has anyone encountered a similar issue or can provide insights into how this might be resolved? Any suggestions or guidance would be greatly appreciated.
Thank you for your assistance.
Issue with Running ARDL Bounds Test in EViews 14 for PMG Model
Abhijeetc19
Re: Issue with Running ARDL Bounds Test in EViews 14 for PMG Model
What's the build date of your copy of EViews 14? (Help->About EViews)
Abhijeetc19
@EViews Gareth the build date of my EViews 14 is Jul 25 2024.
