Impulse response with BVAR
paolo.zanghieri
Postby paolo.zanghieri » Tue Jan 12, 2021 10:29 am
I am trying to get IRF on a BVAR. Each time Eviews requests to restimate the model and then shows all the estimated equations. It happens regardless of the choice of priors but does not happen when I use Bayesian methods for a Mixed Freq. VAR. Please find the wf attached. I am using Version 12, Jan. 8 build
Thanks a lot
us_infl.wf1
(1.29 MiB) Downloaded 22379 times
Re: Impulse response with BVAR
Postby EViews Gareth » Tue Jan 12, 2021 10:46 am
We'll fix.
Postby EViews Gareth » Tue Jan 12, 2021 10:53 am
Fix will be in next patch.
Alvin
Postby Alvin » Fri Nov 25, 2022 11:55 am
Hi, I have two questions regarding IRFs for BVAR. First, for Eviews 12, is there a way to get the standard errors for the IRFs so that I can manually calculate the confidence intervals? Second, does EViews 13 report the confidence bands for the BVAR?
fmramos
Postby fmramos » Mon Mar 04, 2024 9:53 am
Hi all! I successfully estimate a BVAR with about 15 variables à lá Giannone et all. Through Luvsannyam's LBVAR add-in, we have automated confidence intervals, but with EV's feature, I'm unable to get them (light grey for confidence intervals, as per image attached). Any hint? Tks a lot!
Fabio
PS. The same problem with stockwatson.wf1 from BVAR folder in EV examples folder. With the BEAR package for Matlab confidence intervals work nicely (I'm trying to use EV due to its simplicity to format stuff etc)
fmramos
Postby fmramos » Wed Jun 19, 2024 6:20 am
May we count on some updates of the BVAR tool in EViews 14? With credible confidence intervals? At least for now, nothing has changed in the demo version. Best!
fmramos
Postby fmramos » Tue Feb 10, 2026 11:36 am
Hey, EV team,
Even in these days of EV14, we are unable to build CI bands using BVAR objects. Would this be fixed sometime soon? Ty.
F
EViews Kai
Postby EViews Kai » Tue Feb 10, 2026 11:59 am
Hi Fabio,
Thank you for your patience.
We will have credibility intervals for BVAR (but not Bayesian MIDAS) in EViews 15.
We do not have a release date yet for EViews 15, but hopefully this year.
Best,
Kai
