Seasonal adjustment with national calendar
nizinamazowiecka
Is it possible to seasonally adjust a time series in Eviews but using the national calendar (i.e. specific number of working days, specific national holidays)?
Re: Seasonal adjustment with national calendar
The EViews implementation of X-13 allows you to assign a workfile series as a user-variable in the X-13 pre-adjustment regression. You can create at calendar variable similar to those built in to X-13, but supporting you specific calendar.
Recommend reading the X-13 documentation to see how they define their built in calendar variables, then you can copy the idea to your own series, and add that.
uyanikcaner
After Eviews 14 has been released, I have moved to Jdemetra+ for seasonal adjustment. However, I am no longer able to reach the original series by multiplying the seasonally adjusted series (_d11) and the seasonal factors (_d10). I was able to get the original series with the same mathematical operation when using Eviews 13 and X-13. I am also able to reach the original series when using the JDemetra+ application. What is the problem here? Is it an Eviews bug or am I doing it wrong? (Seasonal factors are not additive, they are multiplicative. Although I pay attention to this, it is not working. In addition, calendar effects factors cannot be obtained, will you release any patches for fixing this and adding TRAMO/SEATS procedure in JDemetra+?)
Also, users should have a choice on deciding whether they will be additive or multiplicative seasonal and calendar factors.
Could you email support@eviews.com with a list of things you'd like added/changed, with some examples?
uyanikcaner
Is there any option for checking whether calender effects are statistically meaningful or not while using JDemetra+ on Eviews?
