Hi fellows,
for the attached raw data I have, I conducted Heteroskedasticity Test under Residual Diagnostics section.
You will also find attached outputs for cross-section and period tests. However, I am confused with the outputs. If I consider cross-section weight, I have to reject H0, which says that my data is heteroskedastic. On the other hand, if I proceed with period test, I do not have to reject H0, since it is >0.05 and thus, my data does not suffer from heteroskedasticity and which is the desired case.
How should I read the output? Does my data suffer from heteroskedasticity or not?
Any help will be appreciated!
Thanks,
Ayca
Panel Data Heteroskedasticity LR Test - Output Conflict
aycakaratepe
- RoA3.xlsx
- (44.32 KiB) Downloaded 21931 times
- Screen Shot 2021-03-08 at 5.36.56 PM.png (71.63 KiB) Viewed 76872 times
- Screen Shot 2021-03-08 at 5.36.43 PM.png (73.9 KiB) Viewed 76872 times
Fadi hanieh
Re: Panel Data Heteroskedasticity LR Test - Output Conflict
hi,
i have the same results regarding inconsistency between LR test with time period and LR test with cross section
Did you find a solution to this problem?
regards
regards
