STAR output issues
Re: STAR output issues
Postby EViews Glenn » Wed Aug 30, 2023 1:37 pm
On the original wonky test output... we've identified an issue with the scaling of some collinearity diagnostics. We are testing a fix and hope to have something soon.
Many apologies, and thanks for your patience.
somordha
Postby somordha » Wed Sep 06, 2023 4:38 am
Glenn, hopefully you'll let me know if there's progress on that. Steve
Postby EViews Glenn » Tue Sep 12, 2023 6:01 am
Very sorry about the delay. I wanted to make sure that we sorted everything out correctly.
We've put a fix into the code and testing looks good. It will appear in the next patch (probably early next week).
Thanks for your patience, and I greatly apologize for the inconvenience.
Let me know if you have any other issues or if you are under time pressure.
somordha
Postby somordha » Mon Sep 18, 2023 3:30 am
Thanks Glenn, when the patch is out I'll tackle and revert.
Thanks for your help.
Postby EViews Glenn » Wed Sep 20, 2023 7:27 pm
It's up. Take a look.
somordha
Postby somordha » Wed Sep 27, 2023 10:56 am
Checked out that patch Glenn. Seems to solved some of the problems but I ran on another dataset from a published paper to double check and can't replicate results. Can I PM you the output?
somordha
Postby somordha » Thu Sep 28, 2023 7:19 am
Also, should the delay parameter be entered as a positive or negative number? I get all NAs for errors and t values when I enter as a negative.
somordha
Postby somordha » Wed Oct 04, 2023 3:53 am
Hi folks,
Any chance of an update on this?
Postby EViews Glenn » Wed Oct 04, 2023 10:01 am
Sorry, just saw this. Yes. Please provide, along with as much information as possible. Thanks.
somordha
Postby somordha » Wed Oct 04, 2023 10:13 am
Tried to PM you Glenn but it's just stuck in my Outbox?
somordha
Postby somordha » Thu Oct 05, 2023 2:33 am
Maybe you can PM me and I can reply to you Glenn?
somordha
Postby somordha » Thu Oct 05, 2023 12:13 pm
Got the PM but all of my replies are stuck in my outbox. Also, it won't let me attach any files to the response. What do I need to do?
Postby EViews Gareth » Thu Oct 05, 2023 12:14 pm
You're probably best off emailing support@eviews.com
somordha
Postby somordha » Fri Oct 06, 2023 4:47 am
I've sent results and data to support just now. Thanks.
Users browsing this forum: Google [Bot] and 2 guests
