In my personal time, I've been working on a VS Code language extension for EViews that when complete will support syntax highlighting, intellisense, and some basic command line interaction with EViews that I would be happy to open source. Would EViews have any interest in being the publisher of such an extension on the Microsoft VS Code marketplace? Microsofts TOS seems to be for-profit vendor friendly although I can see why there might be reservations.
Also, one of the things that would be helpful in my development efforts would be direct access to the html reference materials rather than me trying to scrape them. Any chance of that?
Thanks!
VS Code Language Extension for EViews
Re: VS Code Language Extension for EViews
Thanks for reaching out.
We'd be happy to help you on your VS Code language extension for EViews. I don't think we're ready to publish and support it under our own name, but if you want to publish it as an open-source project, we'd be happy to help. You can contact me directly at steve@eviews.com if you have specific technical questions.
Now about the direct HTML references, I've compiled a simple text file that contains all of our objects, object methods & procs, commands, and functions along with the associated URL to the online help page. You can find this file here. This list may also be useful in your attempts to highlight EViews-specific words in your language extension.
Since the URLs can change periodically (caused by the software we use to create them), you should dynamically refer to this text file instead of statically loading it into your project. I'll keep this file updated whenever we add new methods or we change our help page names.
Forgot to mention, to use the URL values, just prepend them with:
As a side note, if you want to open a web page that searches for a particular term in our help system, use this url:
where {searchterm} is the text you're looking for. If your search term includes symbols like '@', make sure you use the URL encoded value of that symbol (e.g. @aic would be %40aic).
https://help.eviews.com/#page/content/Code: Select all
https://help.eviews.com/#search/{searchterm}Re: VS Code Language Extension for EViews
Thank you! I'll follow by email.
johansamuelsson
- Contact:
In this thread, there was (or used to be) a link to, as I understand it, a text file containing all objects, object methods & procs, commands, and functions along with the associated URL to the online help page: https://help.eviews.com/list.txt
It no longer seems to work. Is there any chance you could provide a new one?
We work in UltraEdit, to work with our PRG-files, and use wordfiles to define syntax highlighting. We need to update the syntax highlighting file specifically for EViews.
Regards,
Johan
Regards,
Johan
I restored the original list.txt file that was created July 18, 2023. https://help.eviews.com/list.txt should now work.
johansamuelsson
- Contact:
Many thanks, Steve!
Return to “Any Other Business”
