Data frequency conversion bug
bbonizzi
Postby bbonizzi » Thu Mar 09, 2023 9:34 am
I am trying to convert some series to lower frequency (Monthly/Quarterly to Yearly). This works well when you do it directly, but not through the program. Specifically it does not seem to recognise any of the options for frequency conversion.
For instance using the code:
copy(c=last) Monthly\BOND_ALLOC_TOTAL * copy(c=last) Monthly\EQUITY_ALLOC_TOTAL * copy(c=last) Quarterly\BOND_MARKET *
does not in fact use the last observation of the month/quarter for the yearly values, but actually sums them up.
This problem was pointed out before https://forums.eviews.com/viewtopic.php?t=20275 and recognised as a bug. I was wondering if there were any plans to patch it? I should add that I am still using Eviews 12.
Thank you
Bruno
Re: Data frequency conversion bug
Postby EViews Gareth » Thu Mar 09, 2023 10:33 am
Hello.
Yes, this was fixed in 12.
bbonizzi
Postby bbonizzi » Tue Mar 14, 2023 7:53 am
Thank you. I am using Eviews 12 but the problem persists. Do you mean it was fixed in 13?
Postby EViews Gareth » Tue Mar 14, 2023 9:56 am
No, it was fixed in 12. What's the build date of your copy of 12? (Help->About EViews)
bbonizzi
Postby bbonizzi » Wed Mar 15, 2023 3:49 am
Thanks I use Eviews 12 it through my organisation, and the build is Jul 7 2021. I guess that is not the most up-to-date version?
Postby EViews Gareth » Wed Mar 15, 2023 7:51 am
Correct
