Hello everyone, I used the following commands for iteration of the program:
!use_original_data = 1
!rep_data = 30
!rep_shocks = 500
!irf_steps = 40
!n_paths = 5000
!n_subpath = 1000
rndseed(type=mt) 1234567
But the program is not gonna stop even after 4 hours, and i have to forcefully shut the software. I need guidance that what is the issue here.
Thank you
Itertaion loop does not stop
Re: Itertaion loop does not stop
I'm not sure what you're asking. The code that you listed above will take about a nanosecond to execute.
Thank you for the reply but still the issue is there, Can I email you my workfile and program file so you find out the issue ?I'm not sure what you're asking. The code that you listed above will take about a nanosecond to execute.
Thank you
You have to help us to help you. What are we supposed to do? What is the issue you are facing?
The issue is that when I run the loop as per given commands in options.prg, the loop does not stop even after 4 hours.You have to help us to help you. What are we supposed to do? What is the issue you are facing?
When I run options.prg it runs in about a nanosecond. Is it the other program that's the issue?
