Regression Output
eluerken
Regression Output
Postby eluerken » Wed Mar 24, 2010 3:07 pm
I have several equations, and I would like to create a loop that will output the regressor group, as well as the coefficients associated with each. It's easy to output the regressor group, and I created a matrix that put the unique coefficients above each regressor, but I have a few things I haven't been able to figure out:
1) I would like to have an output with:
Regressor Name_1 Regressor Name_2 .... Regressor Name_k
Coef_1 Coef_2 .... Coef_k
Value_1,1 Value 1,2 .... Value 1,k
But I can't figure out how to do that
2) I have some variables in a PDL, and I would love to automate a function that could include the variables with the regressor group, as well as the number of lags, though I know that this is pretty ambitious.
Any help would be much appreciated.
Re: Regression Output
Postby EViews Gareth » Wed Mar 24, 2010 3:10 pm
An obvious starting point would be to look at this code:
http://forums.eviews.com/viewtopic.php?f=15&t=1631
Postby EViews Gareth » Wed Mar 24, 2010 3:12 pm
You could also take a look at this one (attached)
multi equation grid.prg
(9.59 KiB) Downloaded 546 times
eluerken
Postby eluerken » Wed Mar 24, 2010 3:20 pm
Great! Thanks! I'll check them out!
Riaz
Postby Riaz » Sun May 02, 2010 8:31 am
Hi QMS Gareth
(EViews 7.1)
I wonder whether you have a progam (just like the multi-equation-grid.prg) which outputs the standard diagnostic tests:
(1) Functional Form
(2) Autocorrelation
(3) Heteroscedasticity
(4) Normality
for a set of quations run in a workfile that containts more than 50 or so variables.
Many thanks, Riaz
Postby EViews Gareth » Sun May 02, 2010 3:08 pm
No I do not.
