I am interested in the Solve Control for Target procedure. However, I've never had luck navigating the error messages and can tell I'm doing something wrong. Is there an example workfile anywhere that I can use just so I can better understand and implement the procedure? Such as the workfile for this- https://eviews.com/EViews12/ev12models_n.html
If not, would someone be able to simulate some data with a working model that successfully demonstrates the procedure? I would be really grateful if so.
Regards,
Justin
EViews Matt
Re: Solve Control for Target
Here's a trivial artificial model with an example of using the control procedure over a single variable.
If you share the error message you're encountering I may be able shed some light on what can be done to resolve them. There's quite a variety of errors that could occur, from structural mistakes (e.g. trying to use an exogenous variable to control an endogenous variable that it doesn't influence) to numerical issues (e.g. failing to find control values that satisfy the target series).
wfcreate u 100
series inA = 1 + @abs(@sin(@obsid / 25)) / 2 + rnd / 8
series inB = rnd * @sin(@obsid / 15)
series out
model m
m.append out = inA + inB
m.solve
series out_target = out_0
smpl 81 100
out_target = out_0 * (1 + (@obsid - 80) / 40)
smpl @all
show m
m.control(create) inA out out_target
Matt, thank you very much for the response! This illuminates the procedure for me now that I can follow a worked example.
I tend to encounter this error, "An equal number of control, target, and trajectory variables must be specified." I think part of that is I wasn't understanding the concept of the trajectory variable.
Thanks again,
Justin
Thanks again,
Justin
