How to use temporary variables in state space?
ohubert
Postby ohubert » Thu May 19, 2022 12:59 am
Hi all,
I am trying to automate building a state space to avoid having numerous lines of code.
I want to estimate a relationship for a variable in levels or divided by GDP. I thus have created variables in level and divided by GDP. The structure of the names of the variables is convenient and allows easily selecting one or the other.
However, I do not manage to pass the names to the state space.
I paste below a mock example. I know that this model makes no sense, it is simply there to show what does not work.
wfcreate(wf=annual, page=myproject) a 1950 2005 genr series1=nrnd genr series2= 0.9*series1(-1)+ 0.1*nrnd %stdgdp="gdp" ' shortcut for standarization by GDP: "" for not, "gdp" if yes svector(2) longnames longnames(1) = "series1" +%stdgdp ' append the shortcut for whether it is standardized by GDP or not longnames(2) = "series2" +%stdgdp %varnames1=longnames(1) %varnames2=longnames(2) for !i=1 to 2 ' loop over the variables to create the GDP series %stringtemp2=longnames(!i) 'create temporary variable for the long series {%stringtemp2}gdp= {%stringtemp2}+!i*1000 next ' Not working state space statespace locallevelbis ' Create the state space locallevelbis.append @signal {%varnames1}=mu +[ename = e1, var = exp(c(1))] locallevelbis.append @state mu=mu(-1) +[ename = e2, var = exp(c(2))] locallevelbis.ml
I tried several forms:
longnames(1)
!longnames(1)
%longnames(1)
{longnames(1)}
{!longnames(1)}
{%longnames(1)}
and the same with varnames1, without success.
When using { }, I get the following error message:
Syntax error in "@SIGNAL =MU +[ENAME = E1, VAR =
EXP(C(1))]" in "LOCALLEVELBIS.ML" on line 75.
, which leads me to believe that the temporary variable varnames1 is empty. I confirm this by running the command:
statusline {%varnames1}
Thanks a lot in advance.
Re: How to use temporary variables in state space?
Postby EViews Gareth » Thu May 19, 2022 7:43 am
I'm not sure I follow what you're doing.
The first element in longnames will be equal to:
"series1gdp"
Then, inside your for loop, you store that value into %stringtemp2, then create a series with a name of whatever is inside %stringtemp2, followed by "gdp". Thus, the first time through your loop, the series you create will be called "series1gdpgdp".
You set that series equal to whatever is inside %stringtemp2. Thus the first time through the loop, that line is effectively:
series series1gdpgdp = series1gdp + 1*1000
Which errors, since series1gdp doesn't exist.
ohubert
Postby ohubert » Wed Jun 01, 2022 11:40 pm
Hi Gareth,
Thank you for spotting that error.
Suppose now that the code is the following:
wfcreate(wf=annual, page=myproject) a 1950 2005 genr series1=nrnd genr series2= 0.9*series1(-1)+ 0.1*nrnd %stdgdp="gdp" ' shortcut for standarization by GDP: "" for not, "gdp" if yes svector(2) shortnames shortnames(1) = "short1" shortnames(2) = "short2" svector(2) longnames longnames(1) = "series1" +%stdgdp ' append the shortcut for whether it is standardized by GDP or not longnames(2) = "series2" +%stdgdp %varnames1=longnames(1) %varnames2=longnames(2) series series1gdp=series1 + 1000 series series2gdp =series2 + 2000 ' Not working state space statespace locallevelbis ' Create the state space locallevelbis.append @signal {%varnames1}=mu +[ename = e1, var = exp(c(1))] locallevelbis.append @state mu=mu(-1) +[ename = e2, var = exp(c(2))] locallevelbis.ml ' Not working state space %varnames11="series1" statespace locallevelter ' Create the state space locallevelter.append @signal {%varnames1}=mu +[ename = e1, var = exp(c(1))] locallevelter.append @state mu=mu(-1) +[ename = e2, var = exp(c(2))] locallevelter.ml
Still, locallevelbis or localleverter is unable to plug the variable name into the append command.
Am I doing something wrong or is Eviews unable to do this?
Thank you.
Postby EViews Gareth » Thu Jun 02, 2022 6:32 am
If I run you program, it runs without any errors, and both state spaces appear to estimate fine.
