Can't fetch from DatastreamEDX
blb22
Postby blb22 » Tue May 10, 2022 7:06 am
Having some issues trying to fetch data from a DatastreamEDX library.
80% of the time, the below works flawlessly. But on some occasions, usually on days where I have already fetched a lot of data from the database, it fails. I've already check with Datastream that I've not run over the monthly usage limit, and I can download normally via the Datastream for Excel plugin. So I have an inkling it might be something to do with how the fetch command works in eviews.
Anyone had this kind of issue before?
Re: Can't fetch from DatastreamEDX
Postby EViews Jason » Tue May 10, 2022 8:20 am
Since it appears to work most times but not always, it would imply a network/internet issue. We will reach out to Datastream developers and see if they have any thoughts.
blb22
Postby blb22 » Thu Jun 09, 2022 3:01 am
Thanks.
It's odd, though. I can access the Datastream service via Excel with no problem. It's only Eviews that tends to have an issue. It only really happens after I've fetched a lot of data. But even then, I can still fetch via Excel. Odd...
