Error storing series to database
eviews_5
Postby eviews_5 » Wed Mar 02, 2022 2:41 pm
I've been having trouble with a program storing series from a workfile into a database. An error pops up saying the "db_name.e1a database was not found," but the "db_name.e1a" file is always there when I check in the folder. It's weird because this error only happens sometimes, and I run this program often to create new databases. After I rename the database the program runs fine. Do you have idea why this might be happening?
Thanks.
Re: Error storing series to database
Postby EViews Gareth » Wed Mar 02, 2022 2:49 pm
What's the exact command you are using?
eviews_5
Postby eviews_5 » Thu Mar 03, 2022 2:53 pm
This is the command I'm using:
dbcreate {%dbname} as db
store(d=db) *
Postby EViews Gareth » Thu Mar 03, 2022 4:04 pm
Weird. Nothing springs to mind. Is it a network location? Perhaps there's disk or network io issues going on.
eviews_5
Postby eviews_5 » Fri Mar 04, 2022 1:10 pm
Yes, I'm storing the database to a network location. I'll check if something is wrong with that. Thanks for your help.
