Bai and Perron Sequential test
testeviews123
I am having trouble to find out where the coefficient estimation for the 5 breaks are in EVIEWS when i apply the Bai and Perron Sequential Test in EVIEWS. I cannot find anything on their website about this. They only represent the output given for the breaks that are significant by the sequential test. Yet i wanna see the full output (coefficients, standard deviations p values etc) of the 5 breaks.
Thanks in advance!
Thanks in advance!
Re: Bai and Perron Sequential test
Did you try using the breakls estimation method?
testeviews123
yes but i cannot see the output of coefficients and standard errors T test results for the 5 breaks. I put m=5 and i want to see the results of those 5 coefficients and standard errors T test results.Did you try using the breakls estimation method?
To be more clear I want to see the values of coefficients and standard errors T test results.
Like follows:
break 1 (value of coefficient) (value of standard error) (value of T stat) (P-value) etc...
Because now EVIEWS only report the values when the Sequential Method found the breaks to be significant. But i just wanna see all the values for the 5 breaks
any idea how to retrieve those?
You cannot, other than using fixed number of breaks.
testeviews123
I dont understand the creators of EVIEWS or any other programming language. Why give output but not provide details of the estimation results??? it really doesnt make any sense right? So in order to obtain those estimate what should i do now??You cannot.
Because those results aren't calculated.
testeviews123
huh how come ? When you retrieve an RSS automatically you should get an coefficient and standard deviation T test p value etc right? Am i missing here something? and where do i go wrong in here?Because those results aren't calculated.
No, when you calculate the RSS, you calculate the RSS. You could then, from the RSS, compute other statistics, but that's totally inefficient if you don't need those statistics.
testeviews123
In the Bai and Perron paper (2003) They choose 2 breaks while the sequential method returned 0. They choose the two breaks based upon the Sup(2|1) and Sup(2) 10% level, So now if you wanna write a paper you should also return the coefficients and the respective standard errrors right.No, when you calculate the RSS, you calculate the RSS. You could then, from the RSS, compute other statistics, but that's totally inefficient if you don't need those statistics.
So why leave those results out of the estimation. If you calculate the RSS then you also have the betas and the standard errors t values p value etc.
because the formula is (y-xb)^2=e^2 , where we minimze b , so we would for each segment have the betas and thus the standard errors etc .. so why return the RSS but not those??? you understand me now?
There are many mathematical tricks you can use so that to calculate the series of RSS you don't need to compute individual coefficients, and certainly not standard errors.
You can always use the fixed number of breaks option if you want to view the coefficients and standard errors for two breaks (or any other).
testeviews123
ok so now, I can imagine the tricks being able to conduct in order to obtain coefficients and t stats etc... but why so much hassle for those just provide them because you already have the RSS its just printing the other values. It still doesnt make any sense. I hope the creators will focus on these issues and not come up with recommended tricks but just provide things which are already calculated.
That's the point - coefficients and t-stats are not calculated. If you want to calculate them, it takes extra machine power, which slows down the whole routine.
testeviews123
Not calculated?...The Sum of Squared Residuals i am talking about ... The Sum of Squared Residuals in the Bai and Perron (2003) paper calculates per segment the RSS. So now , it minimizes the coefficients B and Delta right.... (Y-xb-Zdelta)^2 ??? What else does it minimize then ? So now if it minimizes the coefficients B and Delta then just provide their value and related stats such as standard deviations etc...That's the point - coefficients and t-stats are not calculated. If you want to calculate them, it takes extra machine power, which slows down the whole routine.
I feel like we are going round in circles here.
To compute the RSS at each date, you do not need to calculate the coefficients, and you certainly do not need to calculate the standard errors, t-stats.
testeviews123
You make me confused. I am clearly looking at the RSS formula which is RSS=SUM (y-xb)^2=e^2 , so now b has to be estimated first by minimizing (y-xb)^2 with respect to b which turns out to be b=SUM(xy)/SUM(xx) so now then we sum RSS right?I feel like we are going round in circles here.
What am i missing in this ?? Your answers does not clearify the issue enough. If i am wrong in my understanding then explain where i go wrong.
