List of features to include in EViews 13
Postby tvonbrasch » Sat Dec 25, 2021 11:34 pm
Here is an update of the post (http://forums.eviews.com/viewtopic.php?f=8&t=18469) and a list of features (in prioritised order) I hope you can add to Eviews 13:
- Improve window behaviour It would be great if one could fix the windows in EViews so that certain program files were in say one quadrant of the window, workfiles in another, graphs in a third, etc, similar to e.g. Matlab, see http://forums.eviews.com/viewtopic.php?f=8&t=19473
- Remove add-ins using code See the post http://forums.eviews.com/viewtopic.php?f=8&t=19689
- Allow for exogenous variable to enter the cointegrating space in a VEC models, this has been on your to do list for 10 years see: http://forums.eviews.com/viewtopic.php? ... 814#p26814. See also the excellent suggestions in the post http://forums.eviews.com/viewtopic.php?f=8&t=18196
- Improve FLIPTYPE, the new FLIPTYPE command is great, but it does not work with add-factors (see http://forums.eviews.com/viewtopic.php?f=10&t=21164)
- Allow the endogenous variable to be anywhere in an equation, see http://forums.eviews.com/viewtopic.php?f=10&t=19084. (allow the endogenous variable in a model to enter more than once to the left hand side of the equality sign, see http://forums.eviews.com/viewtopic.php? ... 7562#p47562. As it is now, one has to rewrite e.g., logit models to overcome this problem.
- Stochastic simulation of model containing future values of endogenous variables, see User Manual II, page 756 or post:
http://forums.eviews.com/viewtopic.php? ... are#p51947 (a minimum would be to make an addin that passes an Eviews model over to Matlab which is then solved by Dynare (see http://www.dynare.org/) and where the results are automatically transferred back to Eviews)
- Logmode, create list of programs executed from a program-file , see http://forums.eviews.com/viewtopic.php?f=5&t=21137
- ARDL function: allow the user to impose restrictions on the long run cointegrating relationship (eg homogeneity restrictions), see http://forums.eviews.com/viewtopic.php?f=8&t=12027
- Allow for multidimensional matrices : as in Matlab, see: https://www.mathworks.com/help/matlab/m ... rrays.html
- 3D graphs : it should be possible to make 3D graphs in EViews, see post: https://forums.eviews.com/viewtopic.php?t=10899
- Printing of Norwegian vowels in pdf documents, see http://forums.eviews.com/viewtopic.php? ... 378#p53378
- Click-based model simulation and scenario analysis See post: http://forums.eviews.com/viewtopic.php?f=8&t=19136
- Links to PDFs, URLs or Word documents It would be great if one could provide a link to a PDF, a word-file or a web-page in the EViews workfile, see http://forums.eviews.com/viewtopic.php?f=8&t=20091
- Allow for importing data directly using API in Jason-Stat format. There are now plenty of organisations offering data freely using APIs, see http://forums.eviews.com/viewtopic.php? ... tat#p57785
- Allow moving statistics functions inside models, see http://forums.eviews.com/viewtopic.php? ... del#p44355
- Copy all series in a workpage using copy command http://forums.eviews.com/viewtopic.php?f=3&t=19146
- Improve the Eviews optimizer, see http://forums.eviews.com/viewtopic.php? ... 141#p53141.
- Allow Eviews to connect with https addresses, see forum post: http://forums.eviews.com/viewtopic.php?f=3&t=18214
- Make window for active scenario wider see http://forums.eviews.com/viewtopic.php?f=8&t=19681
I am looking forward to EViews 13 :-)
Keep up the great work!
