ARDL FOR 30 EQUATIONS
adarshad
Re: ARDL FOR 30 EQUATIONS
Postby adarshad » Thu Apr 29, 2021 9:44 am
Postby EViews Gareth » Thu Apr 29, 2021 10:00 am
Automating 30 estimations is relatively straight forward, and the programming guide has lots of examples.
Details on how to perform various post estimation tests can be found in the documentation.
Details on how to extract information from a post estimation test can be found in this thread.
adarshad
Postby adarshad » Thu Apr 29, 2021 11:09 am
adarshad
Postby adarshad » Thu Apr 29, 2021 12:56 pm
adarshad
Postby adarshad » Thu Apr 29, 2021 1:38 pm
please help me to write this program so that it performs ardl and then uses selected lag length to ardl long bound cointegration with same lag length and error correction form
!maxlags =6 !bestlag_A= 0 !bestlag_B= 0 !bestlag_C= 0 !bestlag_d= 0 !row=4 for !i=1 to 30 !aic = 99999999 for !lag_A= 0 to !maxlags for !lag_B= 0 to !maxlags for !lag_C= 0 to !maxlags for !lag_d= 0 to !maxlags equation eq{!i}ardl.ardl(deplags=6, reglags=6, trend=none, ic=aic ) x{!i}a x{!i}b x{!i}c x{!i}d if eq{!i}ardl.@aic < !aic then !bestlag_a =(!lag_a) 'if this lag specification has the best AIC, then store this lag as !bestlag. !bestlag_b =(!lag_b) !bestlag_c =(!lag_c) !bestlag_d =(!lag_d) !aic= eq{!i}ardl.@aic equation eq{!i}ardl.cointrep x{!i}a(-!bestlag_a) x{!i}b(-!bestlag_b) x{!i}c(-!bestlag_c ) x{!i}d(-!bestlag_d ) endif show eq{!i}ardl.ardl x{!i}a(-!bestlag_a) x{!i}b(-!bestlag_b) x{!i}c(-!bestlag_c ) x{!i}d(-!bestlag_d ) show eq{!i}ardl.cointrep x{!i}a(-!bestlag_a) x{!i}b(-!bestlag_b) x{!i}c(-!bestlag_c ) x{!i}d(-!bestlag_d ) NEXT NEXT NEXT NEXT NEXT
please can you check and correct for ardl long form bound test estimation too
your little help will save my lot of time
i ran and selected ardl lag length and then i want to run long run ardl bond estimation for selected lag
i hope its easy n simple for you to understand @EViews Gareth and to correct
I want to acheive these for all equations(i)
1.'Make EC equation.
ardldeg.makecoint cointdeg
2;'Run Residual Serial Correlation Test
ardldeg.auto
3;'Run Residual Heteroskedasticity Test
ardldeg.hettest @regs
just even first for this setup would be really beneficial
just correct my code;;;am trying but i cannot understand
Postby EViews Gareth » Thu Apr 29, 2021 2:03 pm
I'm afraid we are not a code-writing or correcting service.
adarshad
Postby adarshad » Thu Apr 29, 2021 3:36 pm
sorry but any suggestion
i am running the program but its not selecting the ardl lag for longrun ardl bound
thanks for your review
