Issue with addin command
For tips, questions and general information about writing Add-ins, how to package them, and how to submit them to EViews for publication.
CrisisStudent
Postby CrisisStudent » Sun Apr 04, 2021 6:51 am
Hi all,
I have problem with creating add-in for string objects using the addin command. Specifically, I run following command, that works for equation and VAR objects fine, but for string object it creates add-in that says the type is string, but the Menu/Procedure type says global, see attached picture.
addin(type="STRING",menu="Specifiation(s) evaluation",proc="speceval",docs=".\documentation\specificatio_evaluation.pdf",desc="performs evaluation of (forecasting properties of) identity(ies) and prepares report summarizing the results.",url="https://github.com/CrisisStudent/SpecEv ... rsion="1.0") ".\specification_evaluation.prg"
This is simply issue of the addin command, as I can create the add-in correctly manually.
Kamil
Addin error.PNG (45.5 KiB) Viewed 69206 times
Re: Issue with addin command
Postby EViews Gareth » Sun Apr 04, 2021 4:01 pm
I’m reasonably confident (although on vacation currently so can’t check definitively) that strong objects can’t have add-ins.
CrisisStudent
Postby CrisisStudent » Mon Apr 05, 2021 12:52 am
Sorry to disturb your vacation!
FYI, I am 100% sure I can create and run the add-in for the string objects, see picture below in terms of set up.
addin strings.PNG (17.77 KiB) Viewed 69174 times
CrisisStudent
Postby CrisisStudent » Wed Apr 07, 2021 2:42 am
Hey guys, I was wondering if you time to look into this? Thanks!
Postby EViews Gareth » Mon Apr 12, 2021 9:14 am
Yep, its a bug. Will be fixed next patch (EV12, poss. 11)
CrisisStudent
Postby CrisisStudent » Wed Apr 14, 2021 12:17 am
Thanks for looking into this!
Return to “Add-in Writing area”
