If statement within a loop for panel data
sky22
Postby sky22 » Wed Mar 03, 2021 1:47 pm
I need advice on a simple program I am trying to run which does not work. I want to include an IF statement within a loop. The data is a panel series in long form, so variable year is a repeated series
SERIES INF
For !YR=1990 to 2017
If year =!yr then
GENR inf=f{!yr}cpi
endif
The series inf remains blank. How do i fix this?
thank you
Re: If statement within a loop
Postby startz » Wed Mar 03, 2021 1:59 pm
Try
smpl if year = !yr inf=f{!yr}cpi smpl @all
sky22
Postby sky22 » Wed Mar 03, 2021 2:07 pm
thank you but the smpl function does not work as the data is a panel. so the sample is country and time. I have a separate variable for year and country.
Is there a way around this?
EViews Matt
Re: If statement within a loop for panel data
Postby EViews Matt » Fri Mar 05, 2021 2:40 pm
If you're saying that variable "year" is a series, then the "year = !yr" expression is not meaningful as part of an if statement conditional. Can you describe what you're trying to accomplish with your code?
