date format not correct in excel
BT454
Postby BT454 » Wed Feb 10, 2021 9:11 am
Hi all!
I'm exporting some unstructured data to excel. One of the series is a stacked "period" series, that is the stacked date.
It seems no matter which way I try to format the data excel is reading it incorrectly.
Here is the workfile and code.
Any and all help is, as always greatly, appreciated!
Thanks!
Bob
wfopen usl48_stdata %exstart = "2016" %exend = hsto001_1.@last wfcreate(wf=gpcm_storage, page=data) m %exstart %exend alpha stor_plan="February2021" copy usl48_stdata::export\hsto*_1 gpcm_storage::data\hsto*_1 copy usl48_stdata::export\lsto*_1 gpcm_storage::data\lsto*_1 wfclose usl48_stdata wfopen can_stdata copy can_stdata::export\hsto*_1 gpcm_storage::data\hsto*_1 copy can_stdata::export\lsto*_1 gpcm_storage::data\lsto*_1 wfclose can_stdata wfsave gpcm_storage group g_hex hsto*_1 group g_lex lsto*_1 series period=@dateval(@datestr(@date)) pagestack(page=hsto) h? @ h? period Stor_Plan alpha stor_code = @left(var01,6) rename h Max_Qty group g_copy period stor_code max_qty Stor_Plan pageselect data pagestack(page=lsto) l? @ l? rename l min_qty !end = @obsrange pagecreate(page=export) u 1 !end copy(g=d) hsto\g_copy export\g_copy copy lsto\min_qty export\min_qty pagesave(t=excel, mode=update) c:\warem32\gpcm_data_lto.xlsx range="input" @keep Stor_Plan Stor_Code Period Min_Qty Max_Qty
Re: date format not correct in excel
Postby EViews Gareth » Wed Feb 10, 2021 9:47 am
You'll need to provide more details.
BT454
Postby BT454 » Wed Feb 10, 2021 11:19 am
No problem.
I've attached an excel file that has the unformatted period series, and the series formatted as "mm/dd/yyyy". The formatted dates do not match the dates in the workfile, and are incorrect. I've also attached the workfile containing the period series, for reference.
I'd like for the period series to export to excel, in a way that it will correctly format to "mm/dd/yyyy". Please let me know if there is any other information that would be helpful, and thank you!
eviews_dates.xlsx
(2.81 MiB) Downloaded 521 times
gpcm_storage.wf1
(25.61 MiB) Downloaded 417 times
Postby EViews Gareth » Wed Feb 10, 2021 3:07 pm
Create a string variable with the date how you want it:
alpha mydate = @datestr(period, "MM/DD/YYYY")
Then save that to the Excel file rather than the period series.
BT454
Postby BT454 » Wed Feb 10, 2021 8:26 pm
thank you sir!
