multivariate GARCH model and programming: inclusion into a model
centroid
Postby centroid » Fri Feb 05, 2021 4:54 am
I would like to write a program which creates a multivariate garch models and then feeds the equations for the variance into a model object. I was able to write the programming code for the creation of the multivariate garch model. But how do I feed the equations for the variance into the model object automatically through a program? Merging the equation only does the trick for the mean equations of the multivariate garch.
Re: multivariate GARCH model and programming: inclusion into a model
Postby EViews Gareth » Fri Feb 05, 2021 6:27 am
Unfortunately the model object can only handle the mean equations.
centroid
Postby centroid » Fri Feb 05, 2021 8:44 am
Is there a way to access the GARCH formula equation with substituted coefficients through the programming interface other than accessing the coefficients individually and then possibly manually entering the identity GARCH equations through a program?
Postby EViews Gareth » Fri Feb 05, 2021 8:57 am
No :/
