How to build a matrix to store coefficients?
nsea411
Postby nsea411 » Mon Jan 25, 2021 5:05 am
Dear friends,
I have regressed 228 regressions now, and I want to build a matrix to store the coefficients and here is my code(unsuccessful to build the matrix) .
wfopen C:\Users\dell\Desktop\data.xls for !i= 1 to 12 'month for !j=2001 to 2019 'year smpl {!j}m{!i} {!j}m{!i} genr a{!j}{!i} =ri genr b{!j}{!i} =roil genr c{!j}{!i} =rm matrix(3,{!j}{!i}) coefs equation eq{!j}{!i}.ls a{!j}{!i} c b{!j}{!i} c{!j}{!i} colplace(coefs, eq{!j}{!i}.@coefs,{!j}{!i}) next next
I try to build a matrix according to http://forums.eviews.com/viewtopic.php?t=1638#p5508(An introduction to EViews programming by Gareth), but because I select subsamples according to date(yyyy-mm) which contains 2 for loops, I don't know how to build a valid matrix and store the coefficients correctly.
If anyone can give me a hand, I will be grateful!
Thank for your kind in advance!
EViews Matt
Re: How to build a matrix to store coefficients?
Postby EViews Matt » Mon Jan 25, 2021 2:52 pm
There's really only two changes needed fix your existing code. First, you don't need to be creating the coefs matrix on every iteration of the loops, that should be done just once before the loops. The number of columns in the matrix can be directly calculated, i.e. 12 * 19 = 228. Second, when using the colplace function, you need to provide a column number as the third argument. The {!j}{!i} expression is going to produce numbers between 20011 and 201912, which clearly isn't appropriate for a matrix that contains only 228 columns. Basically, you need to devise a formula involving !j and !i that will produce an appropriate number between 1 and 228, such as "(!i - 1) * 19 + !j - 2000".
nsea411
Postby nsea411 » Mon Jan 25, 2021 7:37 pm
Thank you very much! I have tried your way and done successfully. :lol:
