Maximum options for add-in
For tips, questions and general information about writing Add-ins, how to package them, and how to submit them to EViews for publication.
CrisisStudent
Postby CrisisStudent » Tue Dec 08, 2020 3:33 am
Hi all,
I have written add-in which has rather large number of user-specified options. I think there is a limit to number of options user can specify - when I run the add-in with large number of options specified I get "Too many arguments in {add-in command}". Can you confirm? If yes, what is the limit and is there a way around this other than separating the add-in in more than one add-ins?
Thanks!
CrisisStudent
Re: Maximum options for add-in
Postby EViews Gareth » Tue Dec 08, 2020 8:41 am
I believe 96, although there are cases where it can be less.
You could combine multiple options into one, I suppose.
CrisisStudent
Postby CrisisStudent » Tue Dec 08, 2020 8:52 am
Thanks. I am way less than 96 (approx 20), so it has to be something else.
EViews Matt
Postby EViews Matt » Thu Dec 10, 2020 11:30 am
The options limit appears to be 25.
CrisisStudent
Postby CrisisStudent » Mon Feb 15, 2021 10:51 am
Ah, ok, thanks. Any way to increase it on your part?
CrisisStudent
Postby CrisisStudent » Mon Apr 26, 2021 8:44 am
Just to follow up on this - the maximum number of options became binding for the SpecEval add-in, which has close to 40 user options, so 25 can be limiting there. Not sure if it is worth addressing on your part, I just wanted to put it in context now that the add-in is out.
EViews Matt
Postby EViews Matt » Mon May 10, 2021 10:10 am
The next patch will double the options limit, which should accommodate your addin.
CrisisStudent
Postby CrisisStudent » Wed Jun 09, 2021 1:48 am
Awesome, thanks!
Return to “Add-in Writing area”
