Conditional inclusion of subroutine
For tips, questions and general information about writing Add-ins, how to package them, and how to submit them to EViews for publication.
CrisisStudent
Postby CrisisStudent » Mon Nov 16, 2020 11:11 am
I am writing add-in and as one option I allow users to specify their own modified subroutine to perform as part of the add-in. The motivation is to allow users to easily incorporate their custom procedure into the add-in that performs many other functions. However, when doing this I am encountering limitations on what is allowed in Eviews. My first attempt was to include the subroutine only if add-in argument is specified, e.g.
Select all if arg="T" then include subname.prg endif
This does not seem to be allowed in Eviews.
The alternative approach was to specify variable path from which to include subroutine and use default path if subroutine program does not exist in the specified location; e.g.
Select all if arg="T" then %subourtine_path = "C:\\documents" else %subourtine_path = "default_path" endif include %subourinte_path
However, it seems that inclusion command cannot use strings, but has to have hardcoded path.
Therefore, the only solution I could figure out was to include default subroutine program from the add-in folder, which the user then would have to modify, i.e. user would not be able to use subroutine program of his own choosing.
Is there any suggested way one can allow conditional inclusion of subroutines or variable path of subroutine files?
Thanks!
CrisisStudent
EViews Matt
Re: Conditional inclusion of subroutine
Postby EViews Matt » Tue Nov 17, 2020 5:45 pm
The include command is unlike other commands in that all includes are processed when a program is loaded, before the program actually begins executing. Consequently, includes cannot benefit from conditional statements or program variables. You can work around this limitation by splitting the program into two parts, a first part that writes the dynamic information (the desired include statements) to a fixed-name auxiliary program, and a second part the includes said auxiliary program and performs the rest of the work. As a working example, suppose I have two different versions of a subroutine, only one of which I want to include in my main program at runtime.
version1.prg:
subroutine get_message(string %m) %m = "Low" endsub
version2.prg:
subroutine get_message(string %m) %m = "High" endsub
Unfortunately, I cannot write my main program as follows:
create u 1 series x = rnd if x(1) < .5 then include version1.prg else include version2.prg endif call get_message(%msg) @uiprompt(%msg)
Instead, I will split my main program and have the first part use a text object to build and save a list of inclusions that the second part will intake.
part1.prg:
create u 1 series x = rnd text include_list if x(1) < .5 then include_list.append include version1.prg else include_list.append include version2.prg endif include_list.save dynamic_includes.prg run part2.prg
part2.prg:
include dynamic_includes.prg call get_message(%msg) @uiprompt(%msg)
Following this approach, your add-in should be to accept user-provided code without unduly limiting the user.
CrisisStudent
Postby CrisisStudent » Wed Nov 18, 2020 1:59 am
Thanks Matt, this should work!
Return to “Add-in Writing area”
