SE & t-stats for descriptive stats
Laurel
Postby Laurel » Sun Nov 15, 2020 6:50 pm
If I have monthly stock price data and generate monthly returns (percentage changes) descriptive statistics, how do I get the standard errors, t-stats, and p-values for the mean, standard deviation, and Sharpe ratio = mean/standard deviation? Thank you!
Re: SE & t-stats for descriptive stats
Postby EViews Gareth » Sun Nov 15, 2020 6:54 pm
You'll have to be more descriptive. p-value for what test?
Laurel
Postby Laurel » Sun Nov 15, 2020 6:57 pm
To determine if the mean, standard deviation, and Sharpe ratio = mean/standard deviation are significantly different from zero. Thank you!
Postby EViews Gareth » Sun Nov 15, 2020 8:36 pm
http://www.eviews.com/help/helpintro.ht ... 23ww204681
That will perform the test, you’ll have to then freeze the results and extract the bits you want.
http://forums.eviews.com/viewtopic.php?f=5&t=18
Laurel
Postby Laurel » Mon Nov 23, 2020 6:51 pm
Is there a way to use robust standard errors for the test, e.g. heteroskedasticity and autocorrelation adjusted similar to the covariance method options in equation estimation (cov=hac)? Thank you!
Postby EViews Gareth » Mon Nov 23, 2020 10:08 pm
Not built in
Postby startz » Tue Nov 24, 2020 7:19 am
Testing for the standard deviation different from zero doesn't make any sense. If the sample standard deviation is different from zero, then so is the true standard deviation.
For the mean, try
ls x c
