IF is not defined
dsdsdsdsd
IF is not defined
Postby dsdsdsdsd » Mon Sep 07, 2020 2:37 am
hello ...
I am getting an error message when I type the following into the command line:
alpha country country = "AU" if crossid = 1
if I remove the
if crossid = 1
part, the command does fill everything with "AU".
I am using eViews 11 University Edition.
- any thoughts
- thanks, Shannon
Re: IF is not defined
Postby EViews Gareth » Mon Sep 07, 2020 6:21 am
You want the @recode command
dsdsdsdsd
Postby dsdsdsdsd » Mon Sep 07, 2020 3:20 pm
like this:
@recode country = "9" if crossid = 1
in the command window??
- thanks, Shannon
Postby EViews Gareth » Mon Sep 07, 2020 3:23 pm
You're probably best off reading through the learning resources available.
http://eviews.com/illustrated/illustrated.html
(Chapter 4 especially)
http://eviews.com/Learning/index.html
(Chapter 3)
dsdsdsdsd
Postby dsdsdsdsd » Mon Sep 07, 2020 3:31 pm
this worked:
COUNTRY=@recode(CROSSID=1,"bbb",COUNTRY)
