Dear All,
I am trying to run a regression for unbalanced panel data set. I have a lot of #N/A cells at my spreadsheet for missing data.
1- If I create a balanced panel workfile, will Eviews remove the individual with not having data in all the periods?
2-How Eviews handles unbalance panel data?
3-how should I create a workfile (if the balanced panel workfile is not correct) and estimate my unbalanced panel?
4- May the regression result vary if an unbalanced panel data set is turned into a balanced panel data set?
5- how can I test heteroskedasticity in a panel in Eviews? there is not such a test in the panel. but there is in time-series. can you please help?
it is very crucial, hope I can get help soon. looking forward to hearing from you.
Re: How Eviews handles unbalance panel data?
Can anyone help me pls?
I only understand the first question, to which the answer is "no".
many thanks for your response.I only understand the first question, to which the answer is "no".
so is it correct if I estimate a panel model while I have a lot of #NA observation in my dataset? as I understood, Eviews will not remove the individual with not having all observation and it will use data whenever it is available? is it correct?
In this case, I can only estimate 1 panel model instead of t period crossectional regression (regressing the equation t times and each time for only two sequential years)? right?
Those are econometric questions to which only you can be the judge.
