Error handling
fi99ggb
Error handling
Postby fi99ggb » Mon Apr 06, 2020 3:07 am
Hello
I am using the setmaxerrs to handle processing errors; however, there are cases when EViews naturally stops, for example, when a file I am instructing to open does not exist or when a file cannot be reshaped. In those cases, I would like to manage the error. For example, when EViews stops I would like to run another program file or a specific part of a program file. I would like to note that my code is quite long and it would be practically difficult to know where the error has taken place.
I hope I make sense. I appreciate that my inquiry is unusual and maybe there is no easy solution.
George
Re: Error handling
Postby EViews Gareth » Mon Apr 06, 2020 8:04 am
You can use @errorcount to check if an error has occured after a line, and then branch based on if it has or not.
fi99ggb
Re: Error handling
Postby fi99ggb » Wed Apr 08, 2020 1:10 am
Thank you!
