Error: Alpha series in specification
moederpaard
Postby moederpaard » Tue Jul 30, 2013 7:44 am
I am trying to run two data sets an equation, both containing dates in the same order and some values. Unfortunately I get the following error message:
Alpha series in specification - SERIES02
@EXPAND can convert to catagorical dummies.
What am I doing wrong?
Thanks in advance
Re: Error: Alpha series in specification
Postby EViews Gareth » Tue Jul 30, 2013 8:03 am
You're trying to use character data in a regression. You can't do that. Your series SERIES02 contains characters, not numbers.
moederpaard
Postby moederpaard » Tue Jul 30, 2013 9:01 am
Thanks for the reply.
However, after checking I did not find any characters except for the second row saying: "Last updated....." There are blank cells, could that be the reason?
For the full information, the cells contain the following:
left lightblue column contains dates,
the first white column contains the same dates,
the second white column contains numerical data. This second column contains differently formatted data from excel.
Last updated: 07/30/13 - 17:58
Imported from '------.xlsx'
1/02/1998      1.6417
1/05/1998      1.6330
1/06/1998      1.6335
1/07/1998      1.6253
1/08/1998      1.6114
1/09/1998      1.6165
1/12/1998      1.6221
1/13/1998      1.6345
1/14/1998      1.6301
1/15/1998      1.6300
1/16/1998      1.6337
Postby EViews Gareth » Tue Jul 30, 2013 9:10 am
Post the workfile.
moederpaard
Postby moederpaard » Tue Jul 30, 2013 9:40 am
See attachment
Postby EViews Gareth » Tue Jul 30, 2013 10:02 am
Yep, that's character data, not numerical data.
Probably the easiest thing to do is clean it up in Excel before moving it into EViews. In all likelihood, it was character data in Excel too.
moederpaard
Postby moederpaard » Wed Jul 31, 2013 6:02 am
Thanks for the help, the problem is solved.
rcan
Postby rcan » Sat May 09, 2015 4:41 am
I want to run a VAR model in Eviews 7. However, after inserting the data an error pops up "alpha series in specification".
How can I solve this error?
See attachment for workfile. There are two variables.
VAR.WF1
(12.89 KiB) Downloaded 493 times
Postby startz » Sat May 09, 2015 8:43 am
Convert sp500 to numbers. Try the @val function.
Fran17
Postby Fran17 » Fri Mar 20, 2020 12:35 pm
Hola! A mi me sale error Alpha series in specifications-PNB
Ayuda por favor, ya revise los datos del PNB y solo tengo datos numéricos
