I have values in my data that make it very difficult to show the (main) variation (big "outliers"). I can cap the axis to show the normal variation, but then I miss the maximum value. Is there a way to present vertical (data)-axis with "gaps"?
Example: Ordinary variation is within 1 to 10, and a few big values above 100. I could set the max-value to e.g. 12 to show the normal variation. But can I make a gap in the axis, like "chopping" off a part between e.g. 15 and 90, so that I both show normal variation and the max-values?
Thanks,
Dagfinn
Vertical axis with "gap"
dagfinnrime
- Contact:
Re: Vertical axis with "gap"
Unfortunately not. You could try switching the x-axis scale to log.
