P-values for Vector Autoregressions
Damien Kunjal
Postby Damien Kunjal » Tue Oct 22, 2019 6:00 am
Dear all,
Is it possible to obtain P-values for VAR (Vector Autoregression) coefficients? The regression output displays the standard error and t-statistics, however, I am trying to obtain the P-values. Is this possible, and if it is, what is the process?
Thank you all.
EViews Matt
Re: P-values for Vector Autoregressions
Postby EViews Matt » Tue Oct 22, 2019 10:00 am
I don't believe the p-values are available from a VAR object. I believe you'd need to write a program to go through the results table, extract each t-statistic, and calculate the corresponding p-value.
Damien Kunjal
Postby Damien Kunjal » Thu Oct 24, 2019 2:11 am
Thank you for your assistance, Matt. 8)
JuanNicolasDamico
Postby JuanNicolasDamico » Fri Jan 01, 2021 6:32 pm
You can.
After you estimate the VAR model, go to the top Menu and select>PROC>MAKE SYSTEM>ORDER BY VARIABLE. A new window will show up, and you should select "Estimate" in the menu bar ( where it says VIEW-PROC-OBJECT--- select estimate), and then click "Ok". (The estimation method is OLS, which is good).
For further details on VAR models you can check the following step by step paper replica of a VAR model: https://youtu.be/SbE8ns0oOTs
Cheers
