Logaritmic scaling in graphs - does it work?
mamo
Postby mamo » Wed Aug 14, 2019 3:37 am
Dear Eviews team,
using EVIEWS 10 March 2018 build, I am wondering if logarithmic scaling in graphs works as expected.
Changing the scale from linear to logarithmic does not seem to change anything in the appearance of the graph, c.f. code below.
Best, mamo
wfcreate a 2000 2010 series x= @trend^2 freeze(mode=overwrite, gra) x.line show gra ' The change in the scaling does not seem to change anything in the appearance of the graph gra.axis(l) log
Re: Logaritmic scaling in graphs - does it work?
Postby EViews Jason » Wed Aug 14, 2019 10:38 am
Actually, the behavior is correct. The reason you are not seeing the log scale is because there is a zero in the data.
If you change the line
series x= @trend^2
to
series x= @trend^2+1
the log scale will appear.
