Spool object settings
Elderfield.A
Postby Elderfield.A » Thu Jul 18, 2019 5:50 pm
Is there any way to adjust the default settings on the spool object when using the show command:
show myspool
This will pull up the object, but I find myself repeatedly changing the zoom to 200% and changing the object box size. It would be great to program these settings in the command.
Adam
Re: Spool object settings
Postby EViews Jason » Thu Aug 08, 2019 9:03 am
Not sure on what you mean by changing the box size but we can certainly add a command to set the zoom level in the next patch
Elderfield.A
Postby Elderfield.A » Sun Aug 11, 2019 10:43 pm
Thanks Jason - that would be helpful.
By box size, I mean the size of the spool object that pops up. It is always a small window (the same size as the workfiles etc.). I then navigate to the small box button (next to the X that closes the window) to enlarge the object.
Postby EViews Jason » Thu Aug 15, 2019 11:16 am
The setzoom command will be available in the next patch.
We will look into adding an option for displaying all object windows at a custom or preset size.
Users browsing this forum: EViews Matt and 2 guests
