HP Filter in Rolling Window mode
For posting your own programs to share with others
JOSE JB
Postby JOSE JB » Fri May 31, 2019 6:13 am
Hello, everyone. I want to share the programming that performs the HP Filter on a Rolling Window mode. It has been coded for one variable, the user can set the window, parameter size (lambda), step of the rolling window of its preference and, of course, get multiple trends and gaps per time span.
Please, note that the code could also be adapted for other univariate filters like the Band-Pass, HP one sided, Kalman Filter, etc. Moreover, a further step could be to adapt it for several groups of variables.
'********** ' HP Filter Rolling Window '********** close @objects smpl @all ' ------------------------------------------------------------------ ' Set your order here string tohp = "x1" ' Set here the name of your variable string inidate = "1995q1" ' Sample (and rolling window) start date string windate = "2005q4" ' Rolling window end date string enddate = "2019q1" ' Sample end date !step = 1 ' Set the step size (1, 2, 3, 4, …) !lambda = 1601 ' Set the lambda ' ---> Now you may run the code <--- ' ------------------------------------------------------------------ ' Do not modify this block from here on smpl {inidate} {enddate} !tspan = @obssmpl smpl {inidate} {windate} !win = @obssmpl !length= !tspan - !win smpl {inidate}-1 {windate}-1 delete hptt* hpcy* group _g {tohp} _g.line for !i = 0 to @round(@abs(!length+!step-1)) step !step for !v =1 to _g.@count %y = _g.@seriesname(!v) {%y}.hpf(lambda=!lambda) {%y}_hp @ {%y}_hpc series hptt{!i} = {%y}_hp series hpcy{!i} = {%y}_hpc {%y}_hp.line {%y}_hpc.line delete {%y}_hp {%y}_hpc next smpl {inidate}+!i {windate}+!i next ' ------------------------------------------------------------------ 'Get your results here group _g hptt* ' Trends _g.line group _gc hpcy* ' Cycles _gc.line ' ------------------------------------------------------------------
Return to “Program Repository”
