simple question on stom and @convert
pcruzd
Postby pcruzd » Wed May 29, 2019 9:36 am
Hi, Im using the stom command in a loop and I can't make the formed matrix not to prompt in every loop its generated, even if the program is running quiet mode. I tryied using @convert as an alternative but it keeps happening. Any hints?
PD. im using Eviews 9
Re: simple question on stom and @convert
Postby EViews Gareth » Wed May 29, 2019 9:42 am
What do you mean by "not to prompt in every loop its generated"? A program such as the follow has no prompting.
create u 10 for !i=1 to 5 series x!i=nrnd stom(x!i, y!i) next
pcruzd
Postby pcruzd » Wed May 29, 2019 9:51 am
by prompting I mean a window with the newly created matrix pops-up in every loop. I thought that it shouldn't by happenign but it does. The program is very similar to the one you wrote
Postby EViews Gareth » Wed May 29, 2019 10:17 am
Does it happen with my program?
pcruzd
Postby pcruzd » Wed May 29, 2019 1:02 pm
It didn't. It turns out its not the stom comand which is causing the window to prompt but the matrix.cov comand that follows in the loop. Is there any way to mute it? Check the program below:
create u 10 group gr for !i=1 to 5 series x!i=nrnd gr.add x!i stom(x!i, y!i) next stom(gr, mat) mat.cov(out=s) ' HERE IS THE PROBLEM
Postby EViews Gareth » Wed May 29, 2019 1:10 pm
do mat.cov(out=s)
pcruzd
Postby pcruzd » Wed May 29, 2019 1:44 pm
It worked perfect, thanks!
