2SLS and IV
ramzan
2SLS and IV
Postby ramzan » Tue Nov 09, 2010 6:51 am
what is the difference between IV and 2SLS.
when they become equal.
Re: 2SLS and IV
Postby startz » Tue Nov 09, 2010 7:00 am
2SLS is a generalization of IV. The two are the same when the number of instruments equals the number of coefficients.
ramzan
Re: 2SLS and IV
Postby ramzan » Tue Nov 09, 2010 8:32 am
can we say that they are equal when the equation is exactly identified .
In 2SLS we replace the endogenous variables with there estimated values. but in eviews , for 2SLS we are giving instruments.
Re: 2SLS and IV
Postby startz » Tue Nov 09, 2010 8:57 am
Yes, that's exactly the right thing to say.
The two methods are just equivalent ways of expressing the same underlying mathematics.
ramzan
Re: 2SLS and IV
Postby ramzan » Tue Nov 09, 2010 9:36 am
One more thing that IVLS can only be applied to exactly identified equation where as the 2SLS can be applied to exactly and over-identified equation as well.
ramzan
Re: 2SLS and IV
Postby ramzan » Tue Nov 09, 2010 10:07 am
GDP M2 GPDI FEDEXP TB6
3578.00 626.40 436.20 198.60 6.56
3697.70 710.10 485.80 216.60 4.51
3998.40 802.10 543.00 240.00 4.47
4123.40 855.20 606.50 259.70 7.18
4099.00 901.90 561.70 291.20 7.93
4084.40 1015.90 462.20 345.40 6.12
4311.70 1151.70 555.50 371.90 5.27
4511.80 1269.90 639.40 405.00 5.51
4760.60 1365.50 713.00 444.20 7.57
4912.10 1473.10 735.40 489.60 10.02
4900.90 1599.10 655.30 576.60 11.37
5021.00 1754.60 715.60 659.30 13.78
4913.30 1909.50 615.20 732.10 11.08
5132.30 2126.00 673.70 797.80 8.75
5505.20 2309.70 871.50 856.10 9.80
5717.10 2495.40 863.40 924.60 7.66
5912.40 2732.10 857.70 978.50 6.03
6113.30 2831.10 879.30 1018.40 6.05
6368.40 2994.30 902.80 1066.20 6.92
6591.90 3158.40 936.50 1140.30 8.04
6707.90 3277.60 907.30 1228.70 7.47
6676.40 3376.80 829.50 1287.60 5.49
6880.00 3430.70 899.80 1418.90 3.57
7062.60 3484.40 977.90 1471.50 3.14
7347.70 3499.00 1107.00 1506.00 4.66
7543.80 3641.90 1140.60 1575.70 5.59
7813.20 3813.30 1242.70 1635.90 5.09
8159.50 4028.90 1393.30 1678.80 5.18
8515.70 4380.60 1566.80 1705.00 4.85
8875.80 4643.70 1669.70 1750.20 4.76
I have the following model
Y_1t=β_10+β_11 Y_2t+ β_12 X_(1t+) β_13 X_(2t)+ u_1t
Y_2t=β_20+β_21 Y_1t+u_2t
The first equation is the income equation where as the second equation is the money supply equation.
Y1:income
Y2: stock of money
X1:investment expenditure
X2: Government expenditure on goods and expenditure.
2SLS manually
Regress endogenous variable on the predetermined variable. In the first step we regress the Yit on the Xit and X2t.
Dependent Variable: Y1
Method: Least Squares
Date: 11/09/10 Time: 18:29
Sample: 1970 1999
Included observations: 30
C 2587.351 72.00106 35.93491 0.0000
X1 1.670732 0.164621 10.14897 0.0000
X2 1.969327 0.098368 20.02005 0.0000
R-squared 0.994756 Mean dependent var 5794.517
Adjusted R-squared 0.994368 S.D. dependent var 1520.432
S.E. of regression 114.1062 Akaike info criterion 12.40678
Sum squared resid 351546.3 Schwarz criterion 12.54690
Log likelihood -183.1016 F-statistic 2560.941
Durbin-Watson stat 0.427806 Prob(F-statistic) 0.000000
then I calculate the predicated value of the Y1t, using following eviews command.
forecast y1hat
to estimate the money supply function results ,Ireplace the Y1t with the y1hat
equation eq02.ls y2 c y1hat
Dependent Variable: Y2
Date: 11/09/10 Time: 18:33
Sample: 1970 1999
C -2198.297 139.0986 -15.80388 0.0000
Y1HAT 0.791598 0.023248 34.05020 0.0000
R-squared 0.976419 Mean dependent var 2388.630
Adjusted R-squared 0.975577 S.D. dependent var 1214.819
S.E. of regression 189.8494 Akaike info criterion 13.39468
Sum squared resid 1009198. Schwarz criterion 13.48809
Log likelihood -198.9202 F-statistic 1159.416
Durbin-Watson stat 0.296090 Prob(F-statistic) 0.000000
but when I am doing this through Eviews built in method
equation eq03.tsls y2 c y1 @ c y1(-1)
Method: Two-Stage Least Squares
Date: 11/09/10 Time: 22:01
Sample (adjusted): 1971 1999
Included observations: 29 after adjustments
Instrument list: C Y1(-1)
C -2208.971 136.0338 -16.23840 0.0000
Y1 0.793461 0.022488 35.28357 0.0000
R-squared 0.978753 Mean dependent var 2449.397
Adjusted R-squared 0.977966 S.D. dependent var 1189.016
S.E. of regression 176.4973 Sum squared resid 841085.2
F-statistic 1244.930 Durbin-Watson stat 0.304181
the results are not same , why?
Re: 2SLS and IV
Postby startz » Tue Nov 09, 2010 10:29 am
try
equation eq03.tsls y2 c y1 @ c x1 x2
ramzan
Re: 2SLS and IV
Postby ramzan » Tue Nov 09, 2010 10:47 am
in the Second data ,i have tried both manually and built in method. Parameters are same but the SE are different, please explain, File is attached .
thanks
2sls dimitrios.docx
(27.5 KiB) Downloaded 1397 times
Re: 2SLS and IV
Postby startz » Tue Nov 09, 2010 10:57 am
thanks
When you substitute the fitted values into the second stage, standard errors are computed incorrectly. It's not a software issue; doing this is called the "forbidden regression." That's why one should always use the TSLS command.
ramzan
Re: 2SLS and IV
Postby ramzan » Tue Nov 09, 2010 12:14 pm
one more i want to ask is that is this correct that the IVLS can only be applied to exactly identified equations where as the 2SLS can be applied to over-identified equation and exactly identified equations.
Re: 2SLS and IV
Postby startz » Tue Nov 09, 2010 12:29 pm
That's a reasonable way to think about the difference, but some of this is just terminology. First, 2sls and IV are identical in the just identified case so 2sls in that case is just a different way of thinking about the estimator, it's not a different estimator. Second, you can redo 2sls as a straighforward instrumental variable estimator by using the fitted values from the first stage as instruments in IV.
gilangwika
Re: 2SLS and IV
Postby gilangwika » Sat May 18, 2019 1:33 pm
Dear all...
excuse me, how can I view the first stage result/report in eviews??
Re: 2SLS and IV
Postby EViews Gareth » Sat May 18, 2019 6:08 pm
Dear all...
No software actually estimates in two stages. If you want to see results from a first stage regression, you have to run that regression separately.
