Hello
I have the version 10 of EViews.
Unexpected, when I select “View; Residual Diagnostics” to perform a Breusch-Godfrey test for serial correlation in the residuals as I usually do, the "Serial Correlation LM Test" option does not appears.
Only the “ARCH LM Test” is present along with the two correlograms options.
What can I do to correct what I think is an anomaly
Thank you
