pagesave with mode=update does not work
fhespeler
Postby fhespeler » Mon Apr 01, 2019 2:55 pm
Dear all,
I attempt to save a alpha series via the command
pagesave(type=excelxml,mode=update) "C:\Users\fhespeler\Desktop\blhelp.xlsx" range="ticker!B1" @keep ticker
but is does not work. I checked for the existence of the file via
@fileexist("C:\Users\fhespeler\Desktop\blhelp.xlsx")
and got a 1 as a result, so the file clearly exists. Also if I exchange mode=update with mode=overwrite, the file is successfully overwritten. What can I do?
My EVIEWS version is EVIEWS 10+ Enterprise Edition
Re: pagesave with mode=update does not work
Postby EViews Gareth » Mon Apr 01, 2019 3:04 pm
Could you define what "does not work" means?
I just tried a quick test, and it seemed to work fine.
wfcreate u 100 alpha ticker = "hello" pagesave(type=excelxml) myfile.xlsx range="b2" @keep ticker ticker = "world" pagesave(type=excelxml, model=update) myfile.xlsx range="b2" @keep ticker
fhespeler
Postby fhespeler » Tue Apr 02, 2019 6:24 am
The first command did not produce any saving results. Could it be that's due to the target file containing EXCEL Bloomberg formulas in another sheet than the target sheet?
Postby EViews Gareth » Tue Apr 02, 2019 7:15 am
Did you try my test program, and did it work?
fhespeler
Postby fhespeler » Tue Apr 02, 2019 7:32 am
Your testfile worked perfectly. It first produced a file with entries "hello" and then overwrote this with entries "world".
