Could someone please help with a simple question?
Each time I create a formula using:
frml z_autos = @qnorm(@ranks(autos)/(@obs(autos)+1))
It saves the formula as:
@qnorm(@ranks(autos,"A","A","1999m12 2019m12")/(@obs(autos,"1999m12 2019m12")+1))
Why is EViews forcing a sample range into the formula? What if I want the range to change as more data is added over time?
I know this is probably a very easy question, but I can't seem to find an answer.
Thank you!
Kevin
FRML Creation and Sampling
Re: FRML Creation and Sampling
Formulas have a fixed sample. There is no way around that
Can you edit the frml smpl to be @pagesmpl ?
frmls only update when an underlying series changes, not when things like workfile ranges, samples, or matrix objects change. So, yes, you can set a frml to be based upon @pagesmpl, but it will never update itself automatically, since @pagesmpl is not a series.
But won't any output based on a frml reflect the current smpl anyway? So using @pagesmpl prevents an invisible conflict between changing the smpl globally and what's buried in the frml.
Oh, I see what you mean. No.
The @ranks and @obs functions won't accept @pagesmpl as an argument.
Got it. Thank you all!
