Exclude vs Drop?
Exclude vs Drop?
Postby tvonbrasch » Mon Jan 07, 2019 9:58 am
what is the difference between exclude and drop?
I tried the drop and override command, and compared it with the exclude and override command, and the simulation yielded different results. I thought it would be the same... should it be the same or have I done something wrong? I thought that the exclude command exogenised a variable, or is it something else this command does?
What is it that I do not understand?
Re: Exclude vs Drop?
Postby EViews Gareth » Mon Jan 07, 2019 10:28 am
Exclude is only for the current scenario and changes a single variable. Drop is for all scenarios and drops the entire estimation object/spec.
If you are only working with a single scenario, and the estimation spec for the variable is univariate (i.e. not a VAR, system, model etc...), they're probably the same:
create u 100 series y=nrnd series x=nrnd model m m.append y=0.5*y(-1)+0.3*x(-1) m.append x = 0.4*x(-1)+0.7*y(-1) m.exclude y m.solve series test1 = y_0 d m model m m.append y=0.5*y(-1)+0.3*x(-1) m.append x = 0.4*x(-1)+0.7*y(-1) m.drop y m.solve series test2 = y_0 show test1 test2
Postby tvonbrasch » Mon Jan 07, 2019 11:55 am
Excellent! thanks for the swift reply. that means that I am doing something wrong. I will see if I can figure it out....
Return to “Models”
