Forecast PMG equations for panel data
Frdmn
Postby Frdmn » Mon Dec 10, 2018 10:34 am
I'm trying to forecast the dependant variable based on regressors but the forecast button for PMG estimation doesn't seem to function and only forecasts in-sample.
I use the following specification:
equation pmg_em_asia.ardl(deplags=3,reglags=3) log(oil_consumption_per_capita) log(revenue_per_capita_real) log(brent_c_l) forecast oil_consumption_per_capita_f
I have data up to 2018Q3 for oil_consumption_per_capita and up to 2021Q4 for revenue_per_capita_real and brent_c_l.
Do you have an idea of what is going on?
Thanks!
ps: I'm using Eviews 10+
F.
macro_EM_Asia.csv
(21.45 KiB) Downloaded 552 times
Re: Forecast PMG equations for panel data
Postby EViews Gareth » Mon Dec 10, 2018 2:06 pm
The PMG forecast does not currently dynamically update the dependent variable in the short run equation, so is, unfortunately, incapable of doing a true dynamic out-of-sample forecast.
Frdmn
Postby Frdmn » Tue Dec 11, 2018 2:34 am
Thank you Gareth,
Is there a command to retrieve short run cross section coefficients then?
Thank you in advance,
F.
Postby EViews Gareth » Tue Dec 11, 2018 8:52 am
=pmg_em_asia.@ardlsrcoefs
