Panel VAR EViews 9
DeVos
Panel VAR EViews 9
Postby DeVos » Fri May 04, 2018 8:17 am
Is there any possibility to estimate a panel VAR in eviews 9?
Kind regards
Re: Panel VAR EViews 9
Postby EViews Gareth » Fri May 04, 2018 8:30 am
Which estimation technique did you have in mind?
pmchileshe
Postby pmchileshe » Tue Jul 17, 2018 8:23 am
Hi Gareth am trying to estimate a Panel VAR using Eviews 10. Is this possible?
Postby EViews Gareth » Tue Jul 17, 2018 8:27 am
pmchileshe
Postby pmchileshe » Wed Jul 18, 2018 2:53 am
I would to estimate a PANEL VAR with either FIXED EFFECTS, RANDOM EFFECTS or USING the GMM. In other words whichever is appropriate.
Regards
Postby EViews Gareth » Wed Jul 18, 2018 7:35 am
None of those are built in, unfortunately.
You could estimate a standard VAR and use @expand(@Crossid) as an exogenous variable which might give you the fixed effects you want.
pmchileshe
Postby pmchileshe » Wed Jul 18, 2018 7:56 am
Thanks Gareth, I have tried it and it has worked. How do include random effects ? or Is there a way of estimating using the GMM?
Postby EViews Gareth » Wed Jul 18, 2018 8:03 am
No.
Postby startz » Wed Jul 18, 2018 8:29 am
Is it possible do do some of this by manually writing out the VAR as a standard regression?
pmchileshe
Postby pmchileshe » Fri Aug 03, 2018 5:22 am
Hi Gareth,
Is it possible to get impulse response functions for Panel VAR if use the @expand(crossid) command in the exogenous section of the VAR window.
Reagds
data.xlsx
(15.41 KiB) Downloaded 1862 times
pmchileshe
Postby pmchileshe » Thu Aug 23, 2018 8:13 am
Dear Gareth,
Reagd
Postby EViews Gareth » Thu Aug 23, 2018 8:29 am
Impulse responses work in exactly the same way as a non-panel VAR.
