@recode
rmoralesaramburu
@recode
Postby rmoralesaramburu » Mon Apr 14, 2014 10:20 am
I would like to know what is wrong for the following code
series ddddd=@recode((dfs_h>dfs_h(-1)) and (dfs<dfs_l),1,0)
It doesn't work, does @recode works with "and", "or" ??
I am trying @recode because I can't use the IF inside a FOR loop.
Re: @recode
Postby EViews Gareth » Mon Apr 14, 2014 10:36 am
Nothing wrong with it that I can see:
create u 100 series dfs_h = @rnd series dfs=@rnd series dfs_l=@rnd series ddddd=@recode((dfs_h>dfs_h(-1)) and (dfs<dfs_l),1,0)
shineK
Contact:
Re: @recode
Postby shineK » Mon Jun 18, 2018 5:53 am
Hi there,
how do i use 2 svector with @recode command?
(related files as attached, please check.)
Actually, the purpose is that if "cusip_alpha" = "scomp_cusp_al", i would like to create a column called DS_s, which is base on "type", in group Scusp, is anyone have better solution for this?
Thank you so much!!!!
900A_Act1_Cusp_test.csv
(66.38 KiB) Downloaded 11654 times
900a_cusip.prg
(1.59 KiB) Downloaded 11339 times
SP500_cusp_s.csv
(316.31 KiB) Downloaded 11521 times
Best,
SK :D
EViews Matt
Re: @recode
Postby EViews Matt » Mon Jun 18, 2018 8:43 am
You could use something like,
series DS_s = @recode(cusip_alpha = scomp_cusp_al, type, na)
and then add DS_s to group Scusp afterword.
shineK
Contact:
Re: @recode
Postby shineK » Tue Jun 19, 2018 12:23 am
Hi Matt,
Thank you for your advise. :)
After i tried, it still have some problem, you may see the picture from the attachment
For example,
R4(cusip_alpha) = R3206(Scomp_cusp_al) = 000360206, then
R4(DS_S) should be 544294(type)
But, as you can see from the attchment, R4(DS_s) shows "NA"
i'm not sure is the reason that my data contain string or @recode command can't not be used like this way...
please help, thanks a lot!!!!!!! :D
%dir="F:\Thesis\Eviews\St11_900A_cusip" %dir1="F:\Thesis\DataFltr_St3\1.Filter\900A_FltrRe\900A_FltrRe_mrg\cusip_alpha\csv" %dir2="F:\Thesis\Eviews\St11_900A_cusip\test_cusp\csv" wfcreate(wf={%country}wf) u 1 5000 import {%dir}\SP500_cusp_s.csv ftype=ascii rectype=crlf skip=0 fieldtype=delimited na="NA" delim=comma colhead=1 eoltype=pad badfield=NA @freq U 1 @smpl @all import {%dir1}\9a_Act1_CuspRun.csv ftype=ascii rectype=crlf skip=0 fieldtype=delimited na="NA" delim=comma colhead=1 eoltype=pad badfield=NA @freq U 1 @smpl @all 'read {%dir}\SP500_cusp_s.csv x1 x2 x3 x4 x5 Scomp_cusp_al $ 'import {%dir2}\900A_Act1_N.csv delim=comma @id cusip_alpha @destid Scomp_cusp_al series DS_s = @recode(scomp_cusp_al = cusip_alpha, type, na) group cuspN scomp_cusp_al s_gvkey syear s_comp_cusip s_comp_tic s_crsp_cusip s_crsp_tic s_crsp_name DS_s
recode command.JPG (217.66 KiB) Viewed 86655 times
Best,
SK :D
EViews Matt
Re: @recode
Postby EViews Matt » Tue Jun 19, 2018 9:49 am
Ah, you want to test if each value in scomp_cusp_al matches ANY value in cusip_alpha, and copy the corresponding type value. @recode is not the way to do this. Basically, you need to manually go through every observation in scomp_cusp_al and search for a matching observation in cusip_alpha.
series DS_s for !i = 1 to @obsrange if scomp_cusp_al(!i) <> "" then for !j = 1 to cusip_alpha.@last if scomp_cusp_al(!i) = cusip_alpha(!j) then DS_s(!i) = type(!j) !j = @obsrange endif next endif next
shineK
Contact:
Re: @recode
Postby shineK » Thu Jun 21, 2018 8:20 am
Hi Matt,
i have another question that i need to create new columns ds_s_F/ds_c_F base on the ds_s/c_{%cntry}({%cntry}=a1, a2, dd1, dd2, dd3, dd4, dd5)
you may see the attached.
If one of ds_s/c_{%cntry} have 'value', ds_s/c_F = 'value', otherwise, = '0'
i not sure @recode command could use in this kind of issue, or not?
thanks a lot!!!
Best,
SK :D
EViews Matt
Re: @recode
Postby EViews Matt » Thu Jun 21, 2018 9:31 am
You want to examine values within each row, yes? For that @recode could work well. However, it's probably easier to use other EViews facilities. For example, you can add the series/columns you want to check to a group and then use @rfirst to identify the first non-NA value for each row of the group. Since your data appears to have only one unique non-NA value per row, identifying the first non-NA value matches what I believe you're requesting. Here's some sample code for ds_s_F,
%names = @wcross("ds_s_", "a1 a2 " + @wcross("dd", "1 2 3 4 5")) group tmp {%names} ds_s_F = @nan(@rfirst(tmp), 0)
shineK
Contact:
Re: @recode
Postby shineK » Fri Jun 22, 2018 12:17 am
Hi Matt,
Thank you so so so much~~~ :D
Best,
SK :D
shineK
Contact:
Re: @recode
Postby shineK » Wed Jun 27, 2018 3:36 am
Hi there,
i would like to do downsize within 2 files as attached.
and, create a new file that when obs = ds_s_F, and keep the obs.
how do i do it?
thanks!!!
ds
return code
Best,
SK :D
EViews Matt
Re: @recode
Postby EViews Matt » Wed Jun 27, 2018 9:17 am
It's unclear to me which observations you want to keep. Regardless, if you can create a dummy series indicating which observations you want to keep, you can then contract the workfile page using that series and save it as a new workfile.
shineK
Contact:
Re: @recode
Postby shineK » Wed Jun 27, 2018 9:33 am
Hi Matt,
i would like to check whether the code in the 2nd pic exist in the column DS_S_F in the 1st pic
if not exist then drop the whole column of the code
for example,
if B1(867270) not exist in the DS_S_F, then drop the column
At the end, it will have a new file with the code that DS_S_F exist
i'm not sure you understand my explanation or not...?
Best,
SK :D
EViews Matt
Re: @recode
Postby EViews Matt » Wed Jun 27, 2018 10:04 am
I understand now, you want to eliminate columns (series), not observations. Once you've imported both files, you can go through each series name of the second file (using @wlookup) and see whether it is present in DS_S_F (similar to the code several posts ago) within the first file. If not, then delete the series.
shineK
Contact:
Re: @recode
Postby shineK » Wed Jun 27, 2018 10:56 am
Hi Matt,
i just try to use @wlookup command, but im not quite sure the function.
i attached 2 files, please check. Thanks!!!
Dret_Mret_test.xlsx
(35.03 MiB) Downloaded 11638 times
CUSIP_FF_run.xlsx
DS_S_F
(53.69 KiB) Downloaded 11584 times
Best,
SK :D
EViews Matt
Re: @recode
Postby EViews Matt » Wed Jun 27, 2018 1:01 pm
Here's an example that gets you part way there. I'd forgotten that EViews will prepend "num" to numeric series names during an import, but that's easy to work around.
wfopen CUSIP_FF_run.xlsx range=CUSIP_FF colhead=1 na="#N/A" @smpl @all wfopen Dret_Mret_test.xlsx range=ACT1_RET_F colhead=1 na="NA" @freq D5 @id @date(obs) @smpl @all copy CUSIP_FF_RUN::Cusip_ff_run\ds_s_f ds_s_f %all_series = @wlookup("num*") for %series {%all_series} !id = @val(@mid(%series, 4)) if @min(@abs(ds_s_f - !id)) <> 0 then delete %series endif next delete ds_s_f
