import excel in eviews 10
jsemeano
Postby jsemeano » Fri May 25, 2018 10:01 am
Dear all,
I am trying to use the import function in eviews 10 but it is not working.
I write
cd D:\DSA
import(type=excelxml) D:\DSA\FQ.xlsm Range="input1!D3:CL2" @Freq A 2016
and eviews says that the file doesn't exist. I tried with different files and I get the same error message does not match expected format in "IMPORT
D:\DSA...
However, I tried a couple of different types in the option and it never worked. Any help appreciated.
Best,
João
Re: import excel in eviews 10
Postby EViews Gareth » Fri May 25, 2018 11:19 am
Are you using the Mac version?
Postby EViews Steve » Fri May 25, 2018 12:49 pm
What happens if you drag the XLSM file onto EViews and use our wizard instead? At the end, you can look at the Captured Command window to see the corresponding IMPORT command.
